Normal Topic Drag Drop (Read 3474 times)
john6630
Drag Drop
Feb 16th, 2017 at 9:01pm
When I drag/drop onto the calendar it returns the date after the date column in my timetable view. I am using the following code in the calendar DragDrop event:
Private Sub calendar_DragDrop(byVal sender as Object, ByVal e as System.Window.Forms.DragEventArgs) Handles calendar.DragDrop
theSelecteDate = calendar.GetDateAt(e.X, e.Y)
End Sub
So if my cursor is in the 02/01 column it returns 02/02 as theSelectedDate. What am I dong wrong?
Thank you,
John Lee
Re: Drag Drop
Reply #1 - Feb 17th, 2017 at 9:22am
The X and Y values of the DragEventArgs class specify mouse position in screen coordinates, while the Calendar.GetDateAt method expects the provided arguments to be in client (for the Calendar control) coordinates. You need to convert the coordinates before calling GetDateAt:
Dim clientPoint As Point = calendar.PointToClient(New Point(e.X, e.Y))
Dim theSelecteDate As DateTime = calendar.GetDateAt(clientPoint.X, clientPoint.Y)
Visio import for BPMN templates
Reply #2 - Feb 17th, 2017 at 12:20pm
Off-Topic replies have been moved to this Topic.
john6630
Re: Drag Drop
Reply #3 - Feb 17th, 2017 at 3:30pm
Thank you for the fast and accurate reply (as usual), Meppy!
