Normal Topic WPF Scheduling: Such a week layout possible? (Read 5061 times)
Heli
Feb 23rd, 2017 at 6:57pm
is such a week layout possible?
(Screenshot from Android App, this question applies to WPF and Xamarin.Scheduling)
Heli
Re: WPF Scheduling: Such a week layout possible?
Reply #1 - Feb 24th, 2017 at 8:59am
This can probably be accomplished but you need to use two Calendar instances and position the one above the other. Will that be OK for you?
Heli
Reply #2 - Feb 24th, 2017 at 10:48am
Yes, sounds good.
That would also give me the possibility to switch on or off the bottom-right sub-calendar (if I don't need it and might want to display some other information in this free cell).
Reply #3 - Feb 24th, 2017 at 2:55pm
Check out this sample. Use the dlls contained in the zip because the SingleWeek WeekRange view only supported grouped weekends and we had to fix that.
Heli
Reply #4 - Feb 24th, 2017 at 3:20pm
that looks promising!
Is the day order also possible like in the screenshot (vertically, left side Monday to Thursday, right side Friday to Sunday)?
Heli
Reply #5 - Feb 24th, 2017 at 3:32pm
This is not currently possible. Days are ordered horizontally first, then vertically. It will be rather hard to do it the other way around as usually this view provides vertical scrolling. Also the items have horizontal orientation and it will be weird if you have items spanning multiple days.
