Normal Topic TimeTableView - capture user change of visible columns (Read 5205 times)
john6630
Mar 2nd, 2017 at 3:50pm
Hi Meppy,
Another question - I would like to capture the number of visible columns when the user makes a change to the visible columns. I do not khnow what event is best to use. I need to save this value so when they reopen the calendar I can reset the number of columns to their last usage.
John
Re: TimeTableView - capture user change of visible columns
Reply #1 - Mar 3rd, 2017 at 10:15am
The control raises TimetableSettings.SettingsChanged event when VisibleColumns value changes - regardless if interactively by user or if set by your code.
john6630
Reply #2 - Mar 4th, 2017 at 3:09am
I can not see how to capture that event. I am using VS2008 and see the event listed in the properties window but do not know how to generate a handler for it. Can you give me some advice?
John
Reply #3 - Mar 6th, 2017 at 8:14am
An alternative would be to inspect the number of visible columns (Calendar.TimetableSettings.VisibleColumns) when the application closes and restore them when it is reopened.
