Hot Topic (More than 10 Replies) Grid zooming causes bizare look (Read 5686 times)
friedel
Mar 9th, 2017 at 10:15am
There is a problem with grid when zooming. This problem occurs not every time, but quite often.
After zooming grid looks like that
http://i65.tinypic.com/28h26ue.jpg
Is it possible somehow solve this problem?
Re: Grid zooming causes bizare look
Reply #1 - Mar 9th, 2017 at 5:12pm
Please check if this build fixes it -
https://mindfusion.eu/_beta/jsdiag_gridzoom.zip
friedel
Reply #2 - Mar 10th, 2017 at 7:11am
I think your biuld fixed problem with zooming, but i found another one. I have JS function
Code (Javascript)
function diagramView_OnNodeMove(sender, args) {
    var margin = nodePosition.width;
    const increment = 25;
    var bounds = getDiagramBounds();
    var left = bounds.left()
    var right = bounds.right();
    var top = bounds.top();
    var bottom = bounds.bottom();
    if (nodePosition.x <= left) {
        left -= increment;
        setDiagramBounds(left, top, right, bottom);
    else if (nodePosition.x >= right - margin) {
        right += increment;
    else if (nodePosition.y <= top) {
        top -= increment;
    else if (nodePosition.y >= bottom - margin) {
        bottom += increment;
function setDiagramBounds(left, top, right, bottom) {
    var diagram = getDiagram();
    var rect = MindFusion.Drawing.Rect;
    var newBoundsRect = rect.fromLTRB(left, top, right, bottom);
    diagram.setBounds(newBoundsRect);
So, after moving node over the edge (left and top) this bug occurs.
http://i65.tinypic.com/308xudk.jpg
http://i63.tinypic.com/8z18q9.jpg
Reply #3 - Mar 10th, 2017 at 2:21pm
Is that a handler for NodeModified event, and where does nodePosition come from? I think you are trying to implement what the built-in AutoResize property does - try setting it to AllDirections and see if it will work for you.
friedel
Reply #4 - Mar 13th, 2017 at 6:54am
Yep, it is a handler for NodeModifyingScript event.
Code (Javascript)
var nodePosition = args.node.getBounds();
I tried to use AutoResize="AllDirections" but it didn't work for me properly. Some times it's working, sometime it's not. And it also has problems with grid. Some lines even disappeared.
Reply #5 - Mar 13th, 2017 at 8:53am
Vertical grid lines stop drawing when they reach right diagram boundary, and horizontal lines stop drawing when they reach bottom boundary. Have you disabled your NodeModified handler when trying AutoResize, so we know whether to look for the problem in the AutoResize code or in your OnNodeMove function?
friedel
Reply #6 - Mar 13th, 2017 at 9:59am
Yes, I disabled NodeModified handler
Reply #7 - Mar 13th, 2017 at 6:04pm
Please let me know what we should change in attached test project to reproduce - try copying your settings and event handlers until that happens.
friedel
Reply #8 - Mar 14th, 2017 at 8:18am
Well, we are using .aspx, so I found it problematic to reproduce this bug on test project.
<%@ Register TagPrefix="ndiag" Namespace="MindFusion.Diagramming.WebForms" Assembly="MindFusion.Diagramming.WebForms" %>
<td id="diagram_window" class="diagramWindowCell resizable">
<ndiag:DiagramView ID="diagramView"runat="server" Behavior="DrawLinks" ClientSideMode="Canvas" EnableItemsDOM="true" AllowInplaceEdit="false"  JsLibraryLocation="../../Scripts/MindFusion/MindFusion.Diagramming.js"         ShapeLibraryLocation="~/Workflow/Designer/ShapeLibrary/DlxCustomShapeLibrary.xml"                             NodeDoubleClickedScript="onNodeDoubleClicked"
NodeCreatingScript="onNodeCreating" NodeCreatedScript="onNodeCreated" NodeSelectedScript="diagramView_OnNodeSelected" NodeDeselectedScript="diagramView_OnNodeDeselection"
LinkCreatingScript ="diagramView_onLinkCreating">
<Diagram RouteLinks="true" GridStyle="Lines" AlignToGrid="True" ShowGrid="True" GridColor="#1B000000" GridSizeY="10" GridSizeX="10"
AdjustmentHandlesSize="8" LinkCrossings="Arcs" HitTestPriority="ZOrder" AllowUnconnectedLinks="false" AutoResize="AllDirections">
</Diagram>
</ndiag:DiagramView>
</td>
Maybe I should have create this topic in ASP.NET section.
friedel
Reply #9 - Mar 14th, 2017 at 10:26am
Hi. I have found another problem - then I creating new diagram and drop node on the edge from nodelist, diagram is automatically resized.
But after I save diagram and put another shape node from nodelist on the edge, autoresizing is not working and shape is looking cropped
Reply #10 - Mar 14th, 2017 at 10:43am
Do you mean after loading a diagram file from client side? That will get fixed when we complete JavaScript XML serialization code of diagram properties we discussed earlier. We should have it ready in a few days, until then you can save and load XML from server-side to make sure nothing is missing.
friedel
Reply #11 - Mar 14th, 2017 at 11:01am
Ok, I will wait for fix.
