Normal Topic Mirroring/Flipping a shape (Read 3556 times)
jarv2003
Mar 22nd, 2017 at 5:00am
How can a shape be mirrored? The shape is not symmetrical.
New Shape( _
                New ElementTemplate() _
                { _
                    New ArcTemplate(0, 0, 85, 85, -32.00538F, 304.3191F), _
                    New LineTemplate(44, 0, 45, 0), _
                    New LineTemplate(45, 0, 100, 0), _
                    New LineTemplate(100, 0, 100, 20), _
                    New LineTemplate(100, 20, 78, 19) _
                }, _
                FillMode.Winding, "ShapeRight")
Please see attached image. How can I mirror the top shape to get the bottom shape.
Your feedback is appreciated
Re: Mirroring/Flipping a shape
Reply #1 - Mar 22nd, 2017 at 6:55am
There's no built-in mirroring available at this time. You could define separate left/right shapes - try subtracting original shape X coordinates from 100 to get symmetrical definition. You can find a method that does that for LineTemplates here -
http://mindfusion.eu/Forum/YaBB.pl?num=1333397142/3#3
For arcs you will also have to reverse sweep angle sign and set start angle to 180 - original value, I think.
Reply #2 - Mar 23rd, 2017 at 7:56pm
We've implemented some built-in support for that here -
https://mindfusion.eu/_beta/diag_flipshapes.zip
Enable the AllowFlip property of ShapeNode and it will flip the shape when you drag an edge over opposite one. You can get or set current flip state using FlipX and FlipY properties.
Reply #3 - Mar 24th, 2017 at 1:35pm
It wasn't flipping shape decoration elements correctly, new build here fixes that -
