Normal Topic ContainerNode、Group Question (Read 1964 times)
JH.Chen
Mar 24th, 2017 at 10:50am
If I Created a ShapeNode as a GroupNode, and had some ShapeNodes inside.
Then I put this GroupNode into a ContainerNode.
When ContainerNode folded, ShapeNodes in GroupNode were still visable.
How can I do, the ShapeNode's master item is GroupNode and when ContainerNode folded , they will not visable ??
Online
Re: ContainerNode、Group Question
Reply #1 - Mar 24th, 2017 at 11:27am
Try setting Group.FollowMasterContainment to true. You were posting in ASP.NET board before? I'm not sure this is available in JavaScript / ASP.NET code.
JH.Chen
Reply #2 - Mar 27th, 2017 at 12:37am
Hi,Slavcho
Thank you.
Yes,I was posted in ASP.NET board before.
I was posted before I saw the Window Forms board.
Actually, I'm using C# window form.
And it work.
Thank you again.
