Normal Topic Tablenode Transparency (Read 2056 times)
crub
Mar 27th, 2017 at 8:34am
Hey,
I've got the problem, that I want to remove the Transparency of a Tablenode, but it's not possible.
Wich property I should use to get this?
Because always when I change the Color of a tablenode, the CaptionBackBrush is in the correct color, and the general Brush is a bit brighter and transparent.
Greets
Re: Tablenode Transparency
Reply #1 - Mar 27th, 2017 at 8:40am
Transparency could also be added by AeroEffect, check if you don't have its instance in Diagram.NodeEffects or table.Effects collections.
crub
Reply #2 - Mar 27th, 2017 at 9:10am
Thanks that solved my Problem.
