Hot Topic (More than 10 Replies) Zoom Control enable with mouse scroll up and down (Read 9422 times)
kelum
Mar 28th, 2017 at 7:59am
I added Zoom Control to canvas dashboard, I want work with that feature with mouse scroll up and down, how can I achieve that ?
Re: Zoom Control enable with mouse scroll up and down
Reply #1 - Mar 28th, 2017 at 8:41am
There's a ZoomFactor property you could set from MouseWheel event handler -
diagram.PreviewMouseWheel += (s, e) =>
	diagram.SetZoomFactor(
		diagram.ZoomFactor + e.Delta / 20,
		e.GetPosition(diagram.DocumentPlane));
	e.Handled = true;
kelum
Reply #2 - Mar 28th, 2017 at 8:53am
This is my main window XAML file
<Window x:Class="MindfusionDigramSample.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        xmlns:local="clr-namespace:MindfusionDigramSample"
        xmlns:diag="http://mindfusion.eu/diagramming/wpf"
        xmlns:mfc="clr-namespace:MindFusion.UI.Wpf;assembly=MindFusion.Common.Wpf"
        mc:Ignorable="d"
        Title="MainWindow" Height="350" Width="525">
    <Grid >
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="200"/>
            <ColumnDefinition />
        </Grid.ColumnDefinitions>
        <Grid.RowDefinitions>
            <RowDefinition Height="500"/>
            <RowDefinition />
        </Grid.RowDefinitions>
        <diag:Ruler x:Name="MindFusionRuler" ShowIcon="False" Grid.Column="1" Grid.Row="0" Grid.RowSpan="2" Grid.ColumnSpan="2" Background="Black" Unit="Inch" Margin="0,0,5,0" FontSize="11">
            <diag:Diagram x:Name="flowchart" AllowDrop="True" RotateCursor="Hand" />
        </diag:Ruler>
        <diag:Overview x:Name="overview" Grid.Column="0" Grid.Row="1" Document="{Binding ElementName=flowchart}"/>
        <diag:NodeListView x:Name="shapeList" Grid.Column="0" Grid.Row="0"/>
        <mfc:ZoomControl
			x:Name="zoomControl"
            Target="{Binding ElementName=flowchart}"
			ScrollStep="40"
			MinZoomFactor="10"
			Height="268"
			VerticalAlignment="Bottom"
			Width="50"
			HorizontalAlignment="Left"
			Panel.ZIndex="1"
			Margin="145,0,0,225" RenderTransformOrigin="0.5,0.5">
            <mfc:ZoomControl.RenderTransform>
                <TransformGroup>
                    <ScaleTransform/>
                    <SkewTransform/>
                    <RotateTransform Angle="-0.476"/>
                    <TranslateTransform/>
                </TransformGroup>
            </mfc:ZoomControl.RenderTransform>
        </mfc:ZoomControl>
    </Grid>
</Window>
So I added mouse event as followings as you said
    public partial class MainWindow : Window
        public MainWindow()
            InitializeComponent();
			shapeList.Items.Add(new ShapeNode { Shape = Shapes.Rectangle, EnabledHandles = AdjustmentHandles.All & ~AdjustmentHandles.ResizeHandles, Bounds = new Rect(0, 0, 60, 30)});
        private void panel1_MouseWheel(object sender, MouseEventArgs e)
            diag.PreviewMouseWheel += (s, e) =>
                e.Handled = true;
but its mentioning 'diag' not in current context
Reply #3 - Mar 28th, 2017 at 9:08am
"diagram" from my code is the name of the Diagram control instance, which is called "flowchart" in your Xaml, so replace it.
kelum
Reply #4 - Mar 28th, 2017 at 11:56am
As you mentioned I changed to following
I registered that method on MainWindow constructor like following
[code]
this.MouseWheel += OnMouseWheel;
[/code]
and implemented that method like following
[code]
private void OnMouseWheel(object sender, MouseWheelEventArgs e)
flowchart.PreviewMouseWheel += (sender, e) =>
flowchart.SetZoomFactor(
flowchart.ZoomFactor + e.Delta / 20,
e.GetPosition(flowchart.DocumentPlane));
e.Handled = true;
[/code]
but here I'm getting following compile time errors
Error 1
"A local or parameter named 'e' cannot be declared in this scope because that name is used in an enclosing local scope to define a local or parameter"
Error 2
"A local or parameter named 'sender' cannot be declared in this scope because that name is used in an enclosing local scope to define a local or parameter"
Reply #5 - Mar 28th, 2017 at 12:15pm
That was a lambda expression set as handler of flowchart's PreviewMouseWheel event. It should look like this converted to event handler method  -
flowchart.PreviewMouseWheel += OnMouseWheel;
    e.Handled = true;
kelum
Reply #6 - Mar 29th, 2017 at 4:30am
As you mentioned I changed that, now its zoom in/out with mouse scroll up/down events, and its mouse scroll up/down working with slider
Since I need to limit this zoom in to 200% and Zoom out to 10% I changed code as below
            if (flowchart.ZoomFactor <= 200 && flowchart.ZoomFactor >= 10)
                flowchart.SetZoomFactor(flowchart.ZoomFactor + e.Delta / 10, e.GetPosition(flowchart.DocumentPlane));
                e.Handled = true;
but if I continuously scroll to zoom in its zooming to 208% then I I try to scroll down to zoom out this canves, but its not zoom out
Reply #7 - Mar 29th, 2017 at 6:24am
The if condition will hold when you are at something like 199 current zoom and the value added by SetZoomFactor will then exceed your limits. Either change condition to flowchart.ZoomFactor <= 200 - e.Delta / 10, or remove the condition altogether and set Math.Max(10, Math.Min(200, newZoom)) as new value.
kelum
Reply #8 - Mar 29th, 2017 at 9:05am
thanks for the help now its working as expected,   I changed as following
flowchart.SetZoomFactor(Math.Max(10, Math.Min(200, flowchart.ZoomFactor + e.Delta / 10)), e.GetPosition(flowchart.DocumentPlane));
e.Handled = true;
var item = flowchart;
but mouse pointer should be in  X > 0 and Y > 0 location,
how to set ruler x and Y starting point as 0 in default window and maximize window ?
Reply #9 - Mar 29th, 2017 at 5:00pm
The ScrollViewer element used inside Ruler always centers its content when it's smaller than the viewer. You could set a large enough diagram.Bounds to make sure it fills maximized window and scroll viewer, see if code here helps -
http://mindfusion.eu/Forum/YaBB.pl?num=1470217247/1#1
It could also be possible to change ScrollViewer control template to top/left align its content instead of centering it, if you prefer to have a smaller diagram canvas.
kelum
Reply #10 - Mar 30th, 2017 at 8:24am
Thanks its worked,
I setup ruler as following
<diag:Ruler x:Name="MindFusionRuler" ShowIcon="False" Grid.Column="1" Grid.Row="0" Grid.RowSpan="2" Grid.ColumnSpan="2" Background="Black" Unit="Inch" Margin="0,0,5,0" FontSize="11" HorizontalAlignment="Left" VerticalAlignment="Top">
                    </diag:Ruler>
kelum
Reply #11 - May 8th, 2017 at 4:08am
currently my zoom control like this
can I change zoom control theme here
Reply #12 - May 9th, 2017 at 4:46am
You can change appearance using Fill, Stroke, CornerRadius and TickPosition properties. If you need to edit the control template, right click the zoom control in VS designer and from context menu select Edit Template -> Edit a Copy command.
