Normal Topic How can we make the canvas only readonly mode? (Read 3817 times)
Ankur shah
Apr 4th, 2017 at 10:19am
I am using diagram.endEdit(true); but it is not working in my case can you please let me know is there any other way to achieve this functionality?
One more question how can we fix the size of canvas? Do i need set it on HTML?
Re: How can we make the canvas only readonly mode?
Reply #1 - Apr 4th, 2017 at 11:05am
endEdit exits in-place editing mode if it's currently active (showing edit-box over a node). If you want to disable double-click text editing, set the AllowInplaceEdit property to false. If you want to disable mouse interactions, set Behavior to DoNothing or SelectOnly.
Ankur shah
Reply #2 - Apr 4th, 2017 at 12:04pm
one more question how can we fix the size of canvas? Do i need set it on HTML?
Actually i need to show whole diagram in a view area as in my diagram it goes beyond view area.
Is there any api which fit the diagram in view area?
Reply #3 - Apr 4th, 2017 at 1:24pm
Size of the canvas element is set by the control, depending on current Bounds, ZoomFactor and MeasureUnit properties. You could call diagram.resizeToFitItems to set Bounds large enough to fit all nodes, and diagram.zoomToFit to apply ZoomFactor that will show everything in the parent div of the canvas.
Lyubo
MindFusion team
Reply #4 - Apr 12th, 2017 at 10:16am
First, set fixed size of the parent div in html:
Code (HTML)
<div style="width: 500px; height: 500px; overflow: auto;">
    <canvas id="diagram"></canvas>
</div>
Next, just call resiteToFitItems to resize the diagram to its contents and then zoomToFit.
Code (Javascript)
$(document).ready(function ()
	var diagram = MindFusion.Diagramming.Diagram.create($("#diagram")[0]);
	diagram.getFactory().createShapeNode(10, 10, 45, 30).init()
		.text('Node 1');
	diagram.getFactory().createShapeNode(75, 25, 45, 30).init()
		.text('Node 2');
	diagram.getFactory().createShapeNode(35, 70, 45, 30).init()
		.text('Node 3');
	diagram.getFactory().createDiagramLink(diagram.getNodes()[0], diagram.getNodes()[1]);
	diagram.getFactory().createDiagramLink(diagram.getNodes()[0], diagram.getNodes()[2]);
	diagram.resizeToFitItems(0);
	diagram.zoomToFit();
Lyubo
