Hot Topic (More than 10 Replies) Stop avoiding overlapping Nodes on Canvas (Read 11043 times)
kelum
Apr 5th, 2017 at 6:23am
Currently mind-fusion canvas can overlap Nodes(Objects) . how to avoid that ?
Re: Stop avoiding overlapping Nodes on Canvas
Reply #1 - Apr 5th, 2017 at 8:06am
kelum
Reply #2 - Apr 5th, 2017 at 8:17am
but where I need to register that `OnNodeModified` method and how to do it ?
Do I need register it on constructor of window like this ?
public MainWindow()
   InitializeComponent();
   flowchart.MouseLeave += OnNodeModified;
Reply #3 - Apr 5th, 2017 at 8:35am
That's a handler for the NodeModified event.
Reply #4 - Apr 5th, 2017 at 9:32am
It's raised once you drop a modified mode. You could do the same from NodeCreated handler for new nodes. If you need to move nearby nodes during mouse movement before dropping a modified node, also handle NodeModifying.
kelum
Reply #5 - Apr 5th, 2017 at 9:36am
but its not triggering once I drag and overlap node items on the canvas,  this is not triggering once I Drop directly Node form Node list
How can I trigger this event when select item from node list and drop it like overlapping ?
kelum
Reply #6 - Apr 5th, 2017 at 9:39am
Now Oky I define it like following
<diag:Diagram x:Name="dia" AllowDrop="True" RotateCursor="Hand" ShowGrid="True" NodeCreated="OnNodeCreated" NodeModified="OnNodeModified"/>
        private void OnNodeModified(object sender, NodeEventArgs e)
            RemoveOverlaps(e.Node, 20);
        private void OnNodeCreated(object sender, NodeEventArgs e)
Thanks lot
kelum
Reply #7 - Apr 5th, 2017 at 9:42am
is there any method, If overlapping dragging Node with existing Node, by giving Waring message and reset dragging object to on its previous location ?
kelum
Reply #8 - Apr 5th, 2017 at 9:53am
I have another question here,
By rotating Node , I can overlap Nodes
So I tried override Hand event like following
diag:Diagram x:Name="flowchart" AllowDrop="True" RotateCursor="Hand" ShowGrid="True" NodeCreated="OnNodeCreated" NodeModified="OnNodeModified"/>
        private void Hand(object sender, NodeEventArgs e)
            RemoveOverlaps(e.Node, 2);
but its not working ?
Reply #9 - Apr 5th, 2017 at 5:04pm
From NodeModifying handler set e.Cancel = true when FindOverlaps returns any nodes. This will show the stop cursor, and return the node to original location if you drop the node there.
Quote:
By rotating Node , I can overlap Nodes So I tried override Hand event like following
RotateCursor is not an event but a property. You should still get NodeModified event raised when a node is rotated. However you might need to extend FindOverlaps to support rotation - try replacing node.Bounds with node.GetRotatedBounds() there.
kelum
Reply #10 - Apr 6th, 2017 at 3:08am
`OnNodeModified` method calling only `RemoveOverlaps` method. its a void method not return anything, so where should I use this `e.Cancel = true` ?
Once I define use like this
            e.Cancel = true;
Getting following error
`'NodeEventArgs' does not contain a definition for 'Cancel' and no extension method 'Cancel' accepting a first argument of type 'NodeEventArgs' could be found`
« Last Edit: Apr 6th, 2017 at 6:33am by kelum »
kelum
Reply #11 - Apr 6th, 2017 at 3:51am
to stop overlap once rotate
as you mentioned I changed `FindOverlap` method following line
 if (bounds.IntersectsWith(node.Bounds))
            to
if (bounds.IntersectsWith(node.GetRotatedBounds()))
but still I can rotate to overlap objects
Reply #12 - Apr 6th, 2017 at 7:45am
Have you also changed the "bounds" variable assignment to use rotated-bounds value?
Quote:
e.Cancel = ...
You can use this in NodeModifying validation event handler; it's different from the NodeModified event you are showing above.
kelum
Reply #13 - Apr 6th, 2017 at 8:30am
to reset to last location if dragging node overlapping with existing node,
I changed xml file like following
<diag:Diagram x:Name="diagramFile" AllowDrop="True" RotateCursor="Hand" ShowGrid="True" NodeModifying="OnNodeModifiying" NodeCreated="OnNodeCreated"
        private void OnNodeModifiying(object sender, NodeValidationEventArgs e)
            e.Cancel = true;
But in `OnNodeModifiying` method how to find nodes that overlapping each other ?
can you mention implementation of `OnNodeModifiying` method
Reply #14 - Apr 6th, 2017 at 1:00pm
private void OnNodeModifying(object sender, NodeValidationEventArgs e)
	e.Cancel = FindOverlaps(e.Node, 5).Count > 0;
FindOverlaps is from thread linked above.
