Hot Topic (More than 10 Replies) Stop avoiding overlapping Nodes on Canvas (Read 11047 times)
kelum
Re: Stop avoiding overlapping Nodes on Canvas
Reply #15 - Apr 7th, 2017 at 4:07am
oky this is working now when drag node already on canvas, but how to revoke the action in following scenarios
Scenario 1
I have NodeList on right panel, select an item from it and drag and drop on canvas, how to avoid if dropping node overlap with existing item
I tried following but it contains compile time errors
        private void OnNodeCreated(object sender, NodeEventArgs e)
            if (IsMovingNodeOverlap(e.Node, 2))
                e.Cancel = true;
            else
                e.Cancel = false;
        public bool IsMovingNodeOverlap(DiagramNode modifiedNode, double minDist)
            bool isCurrentNodeOverlap = false;
            var queue = new Queue<DiagramNode>();
            queue.Enqueue(modifiedNode);
            while (queue.Count > 0)
                var node = queue.Dequeue();
                var nodeCenter = node.GetCenter();
                var overlaps = FindOverlaps(node, minDist);
                if (overlaps.Count > 0)
                    isCurrentNodeOverlap = true;
                else
            return isCurrentNodeOverlap;
Scenario 2
Existing Node can rotate to overlap with another existing node
Reply #16 - Apr 8th, 2017 at 12:13pm
You can set e.Cancel only from validation events, ones with names ending in "ing" like NodeCreating. However NodeCreating is raised only when you draw on the diagram canvas, and not when you drag and drop from the list view control. In latter case you can stop the operation from PreviewDragOver event handler like this -
// in diagram xaml
PreviewDragOver="OnPreviewDragOver"
// in class file
void OnPreviewDragOver(object sender, DragEventArgs e)
	if (e.Data.GetDataPresent(typeof(DraggedNode)))
		var data = (DraggedNode)e.Data.GetData(typeof(DraggedNode));
		var position = e.GetPosition(diagram.DocumentPlane);
		var node = (DiagramNode)data.Node.Clone(false);
		node.Bounds = new Rect(position, node.Bounds.Size);
		e.Effects = DragDropEffects.Copy;
		if (FindOverlaps(node, 0).Count > 0)
			e.Effects = DragDropEffects.None;
			e.Handled = true;
