Normal Topic Mindfusion controls in the toolbox added but not enabled (Read 4588 times)
Francesco
Apr 10th, 2017 at 5:48pm
With the trial version of Mindfusion Diagramming for WPF, I cannot enable the Mindfusion controls in the toolbox. Visual Studio says that the controls are added to the toolbox but are not enabled.
My project's .NET target version is 4.5.2, and I have tried with the Mindfusion CLR 4, but it does not work (neither lowering the .NET version, for instance to 4).
Online
Re: Mindfusion controls in the toolbox added but not enabled
Reply #1 - Apr 10th, 2017 at 6:49pm
What Visual Studio version are you using? Have you run the component's installer or adding it manually to toolbox, e.g. from nuget package?
Francesco
Reply #2 - Apr 10th, 2017 at 6:52pm
VS Enterprise 2017.
Just made drag & drop, following this:
http://www.mindfusion.eu/onlinehelp/flowchartnet/Getting_Started.htm
Francesco
Reply #3 - Apr 10th, 2017 at 6:59pm
And also in the samples, that I successfully run in VS, the toolbox does not show the Mindfusion controls
Online
Reply #4 - Apr 10th, 2017 at 8:00pm
Your project is a WPF one, right? The linked guide is for our WinForms control. In any case we haven't yet released a new version of the diagram after the VS2017 release and haven't tried if our installer works with it. If the samples compile and run fine, you should still be able to use the control - add references to diagramming.wpf.dll and common.wpf.dll, copy the diagram Xaml code from sample Xaml pages to your project, and then the diagram should show in VS designer and load with your application.
Francesco
Reply #5 - Apr 11th, 2017 at 10:41am
Yes, thank you!
Manually it works, but not through the toolbox.
I look forward to an update on your parts!
Online
Reply #6 - Apr 11th, 2017 at 1:36pm
Ok, nice Smiley We should release a new version later this month and will check VS2017 integration then.
Francesco
Reply #7 - Apr 13th, 2017 at 8:04am
It was a mistake of mine, as I had installed the Diagramming version for WinForms.
With theWPF version, the VS 2017 Toolbox correctly imports and shows the Mindfusion controls.
Thank you for your support!
Online
Reply #8 - Apr 13th, 2017 at 8:21am
You are welcome Smiley
