Normal Topic getting canvas content in XML schema (Read 4891 times)
kelum
Apr 11th, 2017 at 5:57am
lets I can save XML file like following, how to get that XML schema in code level
<Diagram Version="17">
  <Nodes />
  <Links/>
  <Properties>
    <ItemCounter>1</ItemCounter>
    <LinkHeadShape Id="Arrow" />
    <Images Count="0" />
    <Stencils Count="0" />
  </Resources>
  <Layers ActiveLayer="-1" />
</Diagram>
I'm trying to get canvas content in to string variable like following
Approach 1
 var canvasContent = diagram.Content;
Approach 2
 var canvasContent = diagram.SaveToString();
but from each of above I cant get exact XML schema like its saving to XML file
Re: getting canvas content in XML schema
Reply #1 - Apr 11th, 2017 at 7:39am
Try with var canvasContent = diagram.SaveToString(SaveToStringFormat.Xml);
kelum
Reply #2 - Apr 11th, 2017 at 8:09am
once I put that getting following compile time error there
`There is no argument given that corresponds to the required formal parameter 'clearDirty' of 'Diagram.SaveToString(SaveToStringFormat, bool)'      `
Reply #3 - Apr 11th, 2017 at 8:23am
add a true or false argument depending on whether you consider this a save operation (the Dirty flag specifies whether diagram has been modified since last save).
kelum
Reply #4 - Apr 11th, 2017 at 8:42am
Now I can see its coming
but how to remove following line or get that xml file without following line
<?xml version="1.0" encoding="utf-16"?>
Reply #5 - Apr 11th, 2017 at 8:46am
Try calling xmlString.Subsrtring(41), if I've counted the characters correctly.
kelum
Reply #6 - Apr 11th, 2017 at 8:59am
I tried following, but not working
string canvasContent = diagram.SaveToString(SaveToStringFormat.Xml.Substring(41), false);
string canvasContent = diagram.SaveToString(SaveToStringFormat.xmlString.Subsrtring(41), false);
Reply #7 - Apr 11th, 2017 at 9:13am
You want to call this on the string returned by SaveToString, so canvasContent = canvasContent.Substring(41);
