Normal Topic Labeling the Nodes (Read 3881 times)
kelum
Labeling the Nodes
Apr 20th, 2017 at 5:38am
I have a requirement to label the nodes that dropping on to canvas, is it possible to do if yes how to do it
Step 1
Step 2
Online
Re: Labeling the Nodes
Reply #1 - Apr 20th, 2017 at 7:49am
Call Diagram.BeginEdit(e.Node) from NodeCreated event handler and it will show a text entry box. If you set AllowInplaceEdit = true, users will be able to edit text by double-clicking.
kelum
Reply #2 - Apr 20th, 2017 at 9:38am
I added following code as you mentioned
        private void OnNodeCreated(object sender, NodeEventArgs e)
            Diagram.BeginEdit(e.Node);
then got following error
cannot convert from 'MindFusion.Diagramming.Wpf.DiagramNode' to 'MindFusion.Diagramming.Wpf.InplaceEditable'
Online
Reply #3 - Apr 20th, 2017 at 9:49am
The interface is implemented by derived node classes, just type-cast the node instance -
Diagram.BeginEdit((InplaceEditable)e.Node);
kelum
Reply #4 - Apr 20th, 2017 at 10:51am
so with below code
I'm getting following error
An object reference is required for the non-static field, method, or property 'Diagram.BeginEdit(InplaceEditable)'
Online
Reply #5 - Apr 20th, 2017 at 12:19pm
Replace Diagram with the name of your instance.
kelum
Reply #6 - Apr 20th, 2017 at 6:02pm
thanks its working Smiley
kelum
Reply #7 - Apr 24th, 2017 at 8:10am
currently once this labels entered its placing left top corner of the node, is it possible to center that label name ?
if yes how can do that?
Online
Reply #8 - Apr 24th, 2017 at 9:01am
Set the node's TextAlignment and TextVerticalAlignment properties.
