Normal Topic Fill calendar to full screen (Read 4240 times)
AncaZ
Apr 27th, 2017 at 7:03am
How can I set the calendar to have to fill all the screen.
This what I have tried:
Code (Java)
final AwtCalendar calendar = createCalendar();
        JPanel entryPanel = PanelFactory.createBorderedPanel(new GridBagLayout(), "Agenda");
        this.setLayout(new BorderLayout());
        JPanel buttonPanel = new JPanel(new FlowLayout(FlowLayout.RIGHT));
        buttonPanel.add(btOpslaan);
        JPanel calendarPanel = new JPanel(new FlowLayout(FlowLayout.RIGHT));
        calendarPanel.add(calendar);
        entryPanel.add(calendarPanel);
        JScrollPane sp = new JScrollPane(entryPanel);
        sp.setBorder(null);
        add(sp, BorderLayout.CENTER);
        add(buttonPanel, BorderLayout.SOUTH);
Thank you
Re: Fill calendar to full screen
Reply #1 - Apr 27th, 2017 at 12:22pm
The calendar can fit inside any size and does not override Java's preferred-size value, so layouts that keep components' preferred size won't work. Try replacing with BorderedLayout.CENTER to force the calendar to occupy all available space available to parent panel -
getContentPane().setLayout(new BorderLayout());
JPanel entryPanel = new JPanel(new BorderLayout());
JPanel calendarPanel = new JPanel(new FlowLayout(FlowLayout.CENTER));
calendarPanel.add(calendar );  */
// BorderLayout.CENTER fill all available space
JPanel calendarPanel = new JPanel(new BorderLayout());
calendarPanel.add(calendar, BorderLayout.CENTER);
entryPanel.add(calendarPanel, BorderLayout.CENTER);
JScrollPane sp = new JScrollPane(calendarPanel);
sp.setBorder(null);
getContentPane().add(buttonPanel, BorderLayout.SOUTH);
getContentPane().add(sp, BorderLayout.CENTER);
