Hot Topic (More than 10 Replies) add a custom property for ShapeNode (Read 8302 times)
kelum
Re: add a custom property for ShapeNode
Reply #15 - May 2nd, 2017 at 9:24am
is this need to serialize and de-serialize also ?
if I want to access above initiated property in another place, how to get it ?
var allNodes = diagram.Nodes;
foreach (var item in allNodes)
// Get the new property Value
string Type = item.Tag.Type;
Reply #16 - May 2nd, 2017 at 10:40am
If you want them saved in XML see how it's done in SiteMap example.
var myTag = (MyTag)item.Tag;
string Type =  myTag.Type;
kelum
Reply #17 - May 3rd, 2017 at 8:14am
With your proposed approach I can see Tag Properties and its values come to code level, then How to bind this Tag Properties to show on XML tag ?
I tried following
binding from code level like this
listNodes.ItemsSource = diagram.Nodes;
then In XML file showing above properties like this
<ListBox Name="listNodes" local:GridControl.Row="0" local:GridControl.Column="0">
<ListBox.ItemTemplate>
<DataTemplate>
<StackPanel Orientation="Vertical">
<TextBlock Text="{Binding Text}" />
<TextBlock Text="{Binding Brush}" />
<TextBlock Text="{Binding Name}" />
<TextBlock Text="{Binding Type}" />
</StackPanel>
</DataTemplate>
</ListBox.ItemTemplate>
</ListBox>
but this is not showing 'Type' on frontend, how to show it ?
Reply #18 - May 3rd, 2017 at 9:15am
{Binding Tag.Type} should work.
