Hot Topic (More than 10 Replies) How to add multiple text to a node? (Read 11093 times)
Re: How to add multiple text to a node?
Reply #15 - Apr 23rd, 2018 at 4:38pm
Try with  -
if (b != null && b.Shape.ToString() == "MyBlock")
Gu Wenwei
Reply #16 - Apr 24th, 2018 at 3:22am
ShapeNode B = node as ShapeNode;
B not null
ShapeNodeEx B = node as ShapeNodeEx;
B is null
I want to get the data from B
Reply #17 - Apr 24th, 2018 at 6:08am
You aren't adding ShapeNodeEx-es to diagram.Nodes then, if building diagrams from code. If you are letting users draw interactively, set DiagramView.Behavior = Custom and CustomNodeType = typeof(ShapeNodeEx) to get ShapeNodeEx instances.
Gu Wenwei
Reply #18 - Apr 25th, 2018 at 1:46am
how to save and open?
Reply #19 - Apr 25th, 2018 at 7:25am
Call RegisterItemClass() to register your custom type for serialization. Implement either SaveTo / LoadFrom methods for binary serialization or SaveToXml / LoadFromXml ones for XML one. E.g. see these topics -
https://mindfusion.eu/Forum/YaBB.pl?num=1203351980/0#0
https://mindfusion.eu/Forum/YaBB.pl?num=1336836718/3#3
Gu Wenwei
Reply #20 - Apr 25th, 2018 at 1:10pm
Code (C++)
        public MainForm()
			InitializeComponent();
            Diagram.RegisterItemClass(typeof(ShapeNodeEx), "ShapeNodeEx", 1);
        class ShapeNodeEx : ShapeNode
            public ShapeNodeEx(ShapeNode prototype) : base(prototype)
            public ShapeNodeEx()
            public string MoreText { get; set; }
            public override void DrawLocal(Drawing.IGraphics graphics, RenderOptions options)
                base.DrawLocal(graphics, options);
                StringFormat drawFormat = new StringFormat();
                graphics.DrawString(MoreText, new Font("Yahei", 7), Brushes.DarkBlue , (float)(Bounds.Width * .5), (float)(Bounds.Height*.85), drawFormat);
            protected override void SaveTo(System.IO.BinaryWriter writer, PersistContext ctx)
                base.SaveTo(writer, ctx);
            protected override void LoadFrom(System.IO.BinaryReader reader, PersistContext ctx)
                base.LoadFrom(reader, ctx);
But the data is disorganized after loading
Reply #21 - Apr 25th, 2018 at 3:55pm
You must save and load your property values from respective methods implementations -
	writer.Write(MoreText);
	MoreText = reader.ReadString();
Gu Wenwei
Reply #22 - Apr 29th, 2018 at 7:40am
Perfect,
Thx
