Normal Topic How do I get the Ruler's scale range? (Read 2236 times)
chowy
May 8th, 2017 at 7:01am
When I use the Ruler Control in WPF, How do I get the Ruler's scale range?? Smiley
Online
Re: How do I get the Ruler's scale range?
Reply #1 - May 8th, 2017 at 2:20pm
It's determined by Diagram.Bounds.
chowy
Reply #2 - May 9th, 2017 at 3:39am
Slavcho wrote on May 8th, 2017 at 2:20pm:
Thanks for your reply!!
but now I have a need,The Mindfusion default drawing origin (0,0) is in the upper left corner,  I want to set the origin of the drawing origin (0,0) to the bottom right corner, do you know how to implement it ? The width and Height of Diagram.Bounds can not be set to a negative number, So I need to know how to set the scale of the ruler to be negative number!
Online
Reply #3 - May 9th, 2017 at 4:23am
You can set Diagram.Bounds to new Rect(-width, -height, width, height), which should end with 0,0 at bottom right. If you need the coordinates to grow from right to left and from bottom to top, the diagram does not support that for its intrinsic coordinates, but you could set Ruler's NegatedX and NegatedY properties to show them as such to users.
