Normal Topic Can I use FlipX and FlipY to implement mirroring? (Read 3357 times)
chowy
May 27th, 2017 at 8:33am
In Diagramming for WPF, version V3.4.3, I saw that "Enable the AllowFlip property and the shape flips when an edge is dragged over its opposite edge". but I now need to click directly through the button, and then achieve horizontal flip and vertical flip. Can I use FlipX and FlipY to achieve it?
Re: Can I use FlipX and FlipY to implement mirroring?
Reply #1 - May 28th, 2017 at 9:30am
Setting these properties is all the control does when it detects edge-over-edge drag, so you should be able to implement mirroring as well by setting them from other event handlers -
void OnObjectFlipHorz(object sender, RoutedEventArgs e)
	var shapeNode = diagram.ActiveItem as ShapeNode;
	if (shapeNode != null)
		shapeNode.FlipX = !shapeNode.FlipX;
chowy
Reply #2 - May 31st, 2017 at 3:39am
Slavcho wrote on May 28th, 2017 at 9:30am:
In the button's click event,I wrote the code
var shape = view.ActiveItem as ShapeNode;
If (shapeNode! = Null)
ShapeNode.FlipX =! ShapeNode.FlipX;
but it does not work, my node is derived from the shapenode,and I override from the draw method. Is there a problem with my draw method? For example, I have a straight draw method:
public override void Draw(DrawingContext graphics, MindFusion.Diagramming.Wpf.RenderOptions options)
            base.Draw(graphics, options);
            TranslateTransform translate = new TranslateTransform(-Bounds.X, -Bounds.Y);
            graphics.PushTransform(translate);
            if (this.IsMove)
                Point oldPoint = translate.Transform(OldBounds.Location);
                TranslateTransform tanslate = new TranslateTransform(-oldPoint.X, -oldPoint.Y);
                StartPoint = tanslate.Transform(StartPoint);
                EndPoint = tanslate.Transform(EndPoint);
                StartPoint = PubTools.SnapPointConvert(StartPoint);
                EndPoint = PubTools.SnapPointConvert(EndPoint);
                Bounds = new Rect(PubTools.SnapPointConvert(Bounds.Location),
                    PubTools.SnapPointConvert(new Point(Bounds.Location.X + Bounds.Width, Bounds.Y + Bounds.Height)));
                OldBounds = Bounds;
                SetDisplayProperty();
            if (IsStartCreate || IsComplete)
                if (EndPoint == new Point(-1, -1) || StartPoint == new Point(-1, -1))
                    return;
                Point start_Point = StartPoint;
                Point end_Point = EndPoint;
                graphics.DrawLine(new Pen(Stroke, StrokeThickness), start_Point, end_Point);
            graphics.Pop();
Reply #3 - May 31st, 2017 at 5:15am
looks like you are comparing with a different variable than the one you assign selection to if that's your literal code (shape vs shapeNode). Also are you sure your base class is ShapeNode?
chowy
Reply #4 - May 31st, 2017 at 5:53am
Slavcho wrote on May 31st, 2017 at 5:15am:
Yes,I'm sure.But in my example startpoint and endpoint are not calculated by bounds.But in my example start point and end point, not calculated by bounds. They are derived from the StartCreate and CompleteCreate methods.
Reply #5 - May 31st, 2017 at 6:25am
FlipX/Y only flip the shape's geometry, and not contained image and text if that's what you expect; you will see their effect only if the shape is not symmetric.
