Normal Topic Serialization + Copying custom Appointment class items from one Timetable to another (Read 5033 times)
Aleksandar
I Love MindFusion! I really
do! :)
Jun 13th, 2017 at 9:11pm
Hello again.
#Q1: How to (Binary if possible, if not, XML example will of course do the job) serialize custom appointment class? Currently, I have this:
using (Stream file = File.Open(fileName, FileMode.Create))
    BinaryFormatter formatter = new BinaryFormatter();
    formatter.Serialize(file, TerminsByIds);
TerminsByIds is just a Dictionary<string, MyTermin>, and the exception is:
Unhandled Exception: System.Runtime.Serialization.SerializationException: Type 'MindFusion.Scheduling.Appointment' in Assembly 'MindFusion.Scheduling.Wpf, Version=3.3.1.10055, Culture=neutral, PublicKeyToken=d12631580350466b' is not marked as serializable.
#Q2: How to achieve this? (note: this was originaly the first question, but I solved it).
I came across some problems while copying a custom Appointment instance (MyTermin is my class' name) from one calendar to another.
I want to have N Calendars (actually only one which changes it's data) with regular TimeTable view, and one global TimeTable which will have columns goruped by resources. Regular calendars are used to add MyTermin both to that one regular calendar and to the global calendar.
Please answer as soon as possible. It would be wonderful if You could do it by 11AM tomorrow.
Many thanks,
Aleksandar
Re: Serialization + Copying custom Appointment class items from one Timetable to another
Reply #1 - Jun 14th, 2017 at 7:59am
The items are not marked as serializable. Instead, you can use the built-in serialization in a XML document. Here is how:
	var doc = new XmlDocument();
	var context = new XmlSerializationContext(calendar1.Schedule, doc);
	Schedule.RegisterItemClass(typeof(MyTermin), "mytermin", 1);
	var rootElement = doc.CreateElement("root");
	doc.AppendChild(rootElement);
	foreach (var item in calendar1.Schedule.Items)
		var itemElement = doc.CreateElement("item");
		rootElement.AppendChild(itemElement);
		item.SaveTo(itemElement, context);
	doc.Save(file);
Note that you need to mark your class as serializable by calling Schedule.RegisterItemClass.
Alternatively, you can rely on binary serialization by using an auxiliary serializable class, which encapsulates only the relevant item properties. For example:
[Serializable]
public class ItemState
	public ItemState(Item item)
		HeaderText = item.HeaderText;
		StartTime = item.StartTime;
		EndTime = item.EndTime;
	public string HeaderText
		get;
		set;
	public DateTime StartTime
		get;
		set;
	public DateTime EndTime
		get;
		set;
An then:
	var formatter = new BinaryFormatter();
		formatter.Serialize(file, new ItemState(item));
Let me know if this helps.
Aleksandar
do! :)
Reply #2 - Jun 14th, 2017 at 10:24am
Meppy wrote on Jun 14th, 2017 at 7:59am:
I will try this now, but I would like to get a deserialization code, since I am not familiar with XML (de)serialization.
Thank You very much!
Kind regards,
Aleksandar
Reply #3 - Jun 14th, 2017 at 11:20am
Here is a sample illustrating XML serialization and deserialization of custom items:
https://mindfusion.eu/_samples/_sample_WpfApplication20.zip
Aleksandar
do! :)
Reply #4 - Jun 14th, 2017 at 12:37pm
Meppy wrote on Jun 14th, 2017 at 11:20am:
Works like a charm! Thank You very very much, sir!
Best wishes,
Aleksandar
