Normal Topic a bug of diagram.Selection.Bounds (Read 2332 times)
chowy
Jun 30th, 2017 at 1:56am
When I write a demo, I test a bug of mindfusion. When I draw a rectangle, when the drawing is done, the rectangle is selected. At this time the data for diagram.Selection.Bounds is correct. The rectangle is selected, modify the size, diagram.Selection.Bounds is still the previous value, not a rectangle modified value.
Re: a bug of diagram.Selection.Bounds
Reply #1 - Jun 30th, 2017 at 9:30am
Do you mean after changing selected node's Bounds from code?
chowy
Reply #2 - Jun 30th, 2017 at 9:37am
Slavcho wrote on Jun 30th, 2017 at 9:30am:
No, after I draw, I did not change the selected state of node, and then drag the selected node directly, this time the node's bounds will be changed. But diagram.selection.bounds does not change.
Reply #3 - Jul 4th, 2017 at 5:33pm
The Selection object gets involved in interaction only when there are multiple items selected and didn't get updated from a single node. This build should update it in that case too -
https://mindfusion.eu/_beta/wpfdiag35.zip
