Normal Topic Add multiple series on bar chart using datatable (Read 3356 times)
abhi dhotre
Jul 12th, 2017 at 5:13pm
Hi All,
I have attached screenshot of the datatable I'm using. I need to have months on Y-Axis, and the columns as different series in barchart. Now, I'm facing following problems:
1) When I'm using one column the bar is displayed but the barchart.series.count() shows count of series as 0. The following is the code:
barChart1.DataSource = dt;
barChart1.XDataFields = new ObservableCollection<string> { "iPhoneSE" }
barChart1.XAxisLabelsDataFields = new ObservableCollection<string> { "TheMonth" }
2) How to add multiple series in a bar chart. I'm using following code but the series count remains to be 0 even if I can see on barchart.
barChart1.YDataFields = new ObservableCollection<string> { "iPhoneSE", "iPhone7", "iPhone6S", "iPhone6" };
3) If I use areaChart then the count of series changes with the same code. But I wanr to display in barchart.
Abhi D Smiley
Re: Add multiple series on bar chart using datatable
Reply #1 - Jul 12th, 2017 at 5:41pm
I think these will show in Series.Count only after you call DataBind. Have you checked the count before or after when using BarChart?
If you want to show multiple series, you can add one column to XDataFields (e.g. Id) and the value columns to YDataFields. As we discussed on the Helpdesk, I will check with our developer if there's a way to show the series without specifying anything in XDataFields.
Also note that instead of setting DataSource and calling DataBind, you can create DataBoundSeries objects and add them to chart.Series, setting X/YDataField for each instance.
abhi dhotre
Reply #2 - Jul 12th, 2017 at 6:08pm
Hey thanks Slavcho, the databind worked. I can get the count of the series now. The only problem now remains with the XDataFields as I do not have any Id column in my datatable.
Abhi
Reply #3 - Jul 12th, 2017 at 6:41pm
Hi Abhi,
Please check if this build works for you -
https://mindfusion.eu/_temp/chart_bind_autoid.zip
It should let you leave XDataFields unassigned and pass the column names to YDataFields.
abhi dhotre
Reply #4 - Jul 12th, 2017 at 7:50pm
Hi Slavcho,
I figured out the problem by adding a dummy ID column in the datatable and it worked as wanted by me. I will check the new libraries and update you on that.
Thanks for your time.
Abhi
