Hot Topic (More than 10 Replies) shapeToolBar shapes (Read 5800 times)
ashar11
shapeToolBar shapes
Jul 18th, 2017 at 6:58am
Can you please tell me how to change the default shapes of shapeToolBar1 with our own custom images like in .png format.
https://imagebin.ca/v/3TlfsbQAHIC7
// shapeToolBar1
this.shapeToolBar1.AllowDrag = true;
this.shapeToolBar1.DropDownArrows = true;
this.shapeToolBar1.Location = new System.Drawing.Point(0, 0);
this.shapeToolBar1.Name = "shapeToolBar1";
this.shapeToolBar1.Shapes = null;
this.shapeToolBar1.ShowToolTips = true;
this.shapeToolBar1.Size = new System.Drawing.Size(954, 94);
this.shapeToolBar1.TabIndex = 8;
this.shapeToolBar1.UseWaitCursor = true;
this.shapeToolBar1.ButtonClick += new System.Windows.Forms.ToolBarButtonClickEventHandler(this.shapeToolBar1_ButtonCli
ck);
thanks
Online
Re: shapeToolBar shapes
Reply #1 - Jul 18th, 2017 at 8:11am
You can assign an array of shape identifiers to the toolbar.Shapes property. You can associate bitmap images with custom shapes by setting the Shape.Image property. ShapeNodes display the shape's image if node's own property is not set.
ashar11
Reply #2 - Jul 18th, 2017 at 11:03am
slavcho thanks for this quick response can u please show me the syntax if possible
Online
Reply #3 - Jul 18th, 2017 at 2:26pm
var customShape = new Shape(Shapes.Rectangle.Outline, FillMode.Winding, "myShape");
customShape.Image = Image.FromFile("icon1.png");
shapeToolBar1.Shapes = new[] { "myShape" };
ashar11
Reply #4 - Jul 19th, 2017 at 6:21am
thank you very much Slavcho.
ashar11
Reply #5 - Jul 21st, 2017 at 1:28pm
How can i define and get the tag for shapetoolbar custom shape,the code is below
When i was using nodelistview for custom shape i was getting the tag with this code
this.nodeListView1.AddNode(new ShapeNode
Transparent = true,
Tag = "Antenna",
         Image = Image.FromFile(@"C:/Imgs/Antenna.png")
}, "Antenna");
MessageBox.Show(e.Origin.Tag.ToString());
ashar11
Reply #6 - Jul 21st, 2017 at 1:38pm
i need tag on diagram_NodeCreated event.
Online
Reply #7 - Jul 21st, 2017 at 2:19pm
The Shape class, whose instances are displayed by ShapeToolbar, does not have Tag property. Maybe you could use Shape.Id or Shape.DisplayName for same purpose.
ashar11
Reply #8 - Jul 22nd, 2017 at 5:37am
Well i was trying to use Id and DisplayName but i cannot get these objects as you can see in the image below
https://imagebin.ca/v/3UDNPsHcjyEk
Error      CS1061 : 'DiagramNode' does not contain a definition for 'Shape' and no extension method 'Shape' accepting a first argument of type 'DiagramNode' could be found (are you missing a using directive or an assembly reference?)'
Online
Reply #9 - Jul 22nd, 2017 at 6:07am
You'll need to typecast to ShapeNode -
var shapeNode = e.Node as ShapeNode;
if (shapeNode != null)
    switch (shapeNode.Shape.Id)
ashar11
Reply #10 - Jul 22nd, 2017 at 6:27am
Thanks this is what i needed.
