Normal Topic Recreating rectangle while moving nodes attached to master node (Group) (Read 2187 times)
PiotrMakowiec
Jul 26th, 2017 at 4:09pm
Hi, I've got some issue :/
I have created group of nodes, by creating ShapeNode and attache other Nodes to it and create rectangle, which is around the group. I wanna mention, that I want to modify nodes inside the group, so that's why their Lock property is set to false.
 private void CreateGroupButton_Click(object sender, RoutedEventArgs e)
         if (FlowChart.Selection.Nodes.Count > 1)
            var groupNode = FlowChart.Factory.CreateShapeNode(0, 0, 1, 1);
            groupNode.ZBottom(false);
            groupNode.Transparent = true;
            groupNode.HandlesStyle = HandlesStyle.MoveOnly;
            CreateGroup(groupNode, FlowChart.Selection.Nodes);
            foreach (DiagramNode node in groupNode.SubordinateGroup.AttachedNodes)
               node.Locked = false;
            groupNode.SubordinateGroup.AutoDeleteItems = true;
            FlowChart.Selection.Change(groupNode);
      private static void CreateGroup(DiagramNode node, DiagramNodeCollection children)
         Rect r = Rect.Empty;
         foreach (var child in children)
            Rect cb = child.Bounds;
            r = r.IsEmpty ? cb : Rect.Union(r, cb);
         double margin = 5;
         r.Inflate(margin, margin);
         node.Bounds = r;
            child.AttachTo(node, AttachToNode.TopLeft);
And my problem is, when I am modifying nodes inside the group. I'd like rectangle is adjusting to the position of the nodes. That's why I am creating rectangle every time node is modifying, but I don't know the node starts changing its size, when I only move it. Below it's the code:
private void FlowChart_NodeModifying(object sender, NodeValidationEventArgs e)
         var nodes = FlowChart.Selection.Nodes;
         var masterGroup = nodes.First().MasterGroup;
         if (masterGroup != null)
            var children2 = masterGroup.AttachedNodes.Cast<DiagramNode>();
            var diagramCollection = new DiagramNodeCollection();
            foreach (var diagramNode in children2)
               diagramCollection.Add(diagramNode);
            var masterNode = masterGroup.MainItem;
            if (masterNode != null)
               Regroup(masterNode as DiagramNode, diagramCollection);
      private void Regroup(DiagramNode node, DiagramNodeCollection children)
            if (r.IsEmpty)
               r = cb;
            else
               r = Rect.Union(r, cb);
         double margin = 5;
         node.Bounds = r;
I wonder if you know, what issue it can be.
Thanks for your help.
Re: Recreating rectangle while moving nodes attached to master node (Group)
Reply #1 - Jul 26th, 2017 at 5:18pm
The Bounds setter also moves related links and subordinate nodes. Try replacing it with this instead -
    node.SetBounds(r, false, false);
If the group node stays invisible, maybe do that just once from NodeModified handler.
PiotrMakowiec
Reply #2 - Jul 26th, 2017 at 7:30pm
Slavcho thank you so much  Smiley Quote:
solved the problem.
Best regards
