Normal Topic Can I have logarithmic interval for Y-Axis (Read 4272 times)
abhi dhotre
Jul 31st, 2017 at 5:28pm
I want Y-Axis of the graph to be of logarithmic interval, for eg : starts from 1, then 10, 100, 1000, 10000 and so on.
Abhi D  Smiley
Re: Can I have logarithmic interval for Y-Axis
Reply #1 - Jul 31st, 2017 at 6:26pm
Hi Abhi,
There's no built-in support for that at this time. You could try creating an adapter Series class whose GetValue method returns the base-10 logarithm of original series' value. This should draw logarithmic graphic, but coordinates on the axis won't match it. If you also want to show coordinates, I guess you could use custom data labels instead.
Reply #2 - Aug 1st, 2017 at 12:18pm
Please find an example attached. You can pass your current series to the LogSeriesAdapter class to transform their values to logarithmic scale. The labels are replaced with logarithmic ones using a formatter assigned to barChart.YAxis.CustomFormat.
LogChart.zip (Attachment deleted)
abhi dhotre
Reply #3 - Aug 1st, 2017 at 3:35pm
Thanks alot Slavcho.  Smiley
