Normal Topic Modify appointments (Read 3125 times)
Ionut Murarasu
Modify appointments
Aug 1st, 2017 at 12:22pm
I see that if you want to block the user from edit the text from appointments you have to call calendar.setAllowInplaceEdit(true) - using this functionality all the appointments from the calendar are read only, can't be edited;
But if I want to block only a few appointments from my calendar to be read only ?
For example I have 10 appointments, 5 of them I want to be read only(user can't change the text) and rest of them I want to let the user to modify the text.
Can you help me please with this problem?
Ionut.
Re: Modify appointments
Reply #1 - Aug 1st, 2017 at 2:26pm
You should listen to the itemInplaceEditStarting event of the calendar:
calendar.addCalendarListener(new CalendarAdapter() {
    void itemInplaceEditStarting(ItemConfirmEvent e) {
        if (!canEdit(e.getItem())
            e.setConfirm(false);
The canEdit function should check if the item can be in-place edited.
Ionut Murarasu
Reply #2 - Aug 3rd, 2017 at 6:48am
Was useful.
Thanks !
