Normal Topic how does the line's thickness not follow the zoom? (Read 1668 times)
chowy
Aug 9th, 2017 at 8:12am
Regardless of enlarge or reduce the number of times, the line thickness remains the same. Just like CAD lines!
Re: how does the line's thickness not follow the zoom?
Reply #1 - Aug 9th, 2017 at 11:27am
Try something like this but modifying StrokeThickness instead of FontSize -
https://mindfusion.eu/Forum/YaBB.pl?num=1294213448/1#1
It could also be possible to do it using bindings to ZoomFactor but you'd need to create a custom value converter.
chowy
Reply #2 - Aug 9th, 2017 at 11:49am
Thank you for your answer.
