Normal Topic Version 6.5 beta (Read 1216 times)
Version 6.5 beta
Aug 14th, 2017 at 12:55pm
FlowChart.NET version 6.5 contains the following new features and improvements -
Non-blocking layout methods
All graph layout classes now contain an async ArrangeAsync method that runs layout calculations in a background task. This is only available in .NET 4.5 build of the diagram assemblies.
async void OnLayoutLayered(object sender, EventArgs e)
	var layout = new LayeredLayout();
	await layout.ArrangeAsync(diagram);
	diagramView.ZoomToFit();
  • ImagePadding property of ShapeNode, TableNode and Cell lets you set padding space between element's borders and their Image.
  • LinksPadding property added to LayeredLayout specifies how much space to leave between links when LinkType is set to Cascading.
  • Merge indicators for cascading links now supported as counter-parts of branch indicators from the 6.4.3 release. Set the LinkMergeIndicator property to specify the indicator shapes and MergeIndicatorColor and MergeIndicatorSize properties to customize their appearance.
  • Export overloads that write to Stream objects added to PdfExporter, VisioExporter and Visio2013Exporter.
  • PageAdding validation event added too TabbedDiagramView.
  • ContainerNodes now apply the TextPadding value.
  • Public TreeViewConnectionPoint.Item property provides access to target TreeViewItem of links.
If anyone is interested in trying the beta version, please download this archive containing updated assembly files -
https://mindfusion.eu/_beta/fcnet65.zip
