Normal Topic can the diagram.Selection draw slection's bounds? (Read 1219 times)
chowy
Aug 17th, 2017 at 9:43am
I want to inherit the Selection class and then override the DrawHandles method. Realize the kind of style in the picture.And I want to drag the handle to modify the size of the selection.
Re: can the diagram.Selection draw slection's bounds?
Reply #1 - Aug 17th, 2017 at 1:17pm
You cannot inherit the Selection class at this time. Try drawing handles from the DrawForeground event handler instead. To initiate resize you will need to create custom BehaviorBase -derived class that returns new InteractionState(Diagram.Selection, new NodeAdjustmentHandle(NodeHandleType....), Action.Modify) from StartDraw override.
