Normal Topic VirtualizingDiagram ViewModels (Read 1157 times)
gabitzu6
Aug 18th, 2017 at 2:04pm
On the VirtualizingDiagram are the two DependencyProperties NodesSource and  LinksSource on which I can bind my Nodes and Links.
The question is what properties are supported?
How can my Node and Link object that I bind to this sources looks?
Are all the properties that are on DiagramNode / DiagramLink supported?
Thank you!
Re: VirtualizingDiagram ViewModels
Reply #1 - Aug 18th, 2017 at 3:04pm
Data items from NodeSource and LinkSource are set as DataContext of actual nodes and links created. For nodes you could add {Binding} expressions in their Xaml templates that bind to properties of the data item. Links aren't drawn using templates at this time, you could probably still add binding expressions from code-behind in LinkRealized event handler, or just set hard-coded appearance properties there.
