Normal Topic A problem with link! (Read 2483 times)
chowy
Aug 23rd, 2017 at 9:53am
After we made the link, we found a problem. When the link to connect to the node, we have some lines under the magnification, there will be broken and staggered situation. Our links are connected to the anchor.
Re: A problem with link!
Reply #1 - Aug 23rd, 2017 at 11:12am
In what manner are you creating links? If using the Cascading link shape, there might be a tiny horizontal segment at that location, you can verify by selecting the link and checking if selection handles appear over control points. If it's a Polyline link, I guess it could look like this if the segment is very slightly inclined.
chowy
Reply #2 - Aug 24th, 2017 at 2:08am
It's a Polyline link.Set the diagram.Zoomfactor to a certain value of the case will appear, but in some cases does not appear. The thickness of my link is dynamically calculated. I would have thought it would be caused by the calculated thickness. Can you fix this problem?
Reply #3 - Aug 24th, 2017 at 7:15am
I don't think it's from thickness, more likely there's a slight horizontal offset between end points of the link segment. Depending on whether it's first or last segment, try setting X coordinate of second or next-to-last point to the X of first / last point to see if that straightens the segment.
chowy
Reply #4 - Sep 4th, 2017 at 6:44am
Slavcho wrote on Aug 24th, 2017 at 7:15am:
But the link's StartPoint and EndPoint are exactly the same as the coordinates of AnchorPoint on node.
Reply #5 - Sep 4th, 2017 at 7:38am
Please attach saved diagram file showing that.
