Normal Topic Values truncated for small values in bar chart control (Read 3036 times)
abhi dhotre
Sep 5th, 2017 at 7:33pm
I'm using a stacked bar chart and want to display all the values of bars(any data labels i.e.inner or outer). In the attached picture you can see that the values are truncated because of the small values of bars on the right. Currently, I'm using inner but evn if I use outerdatalabels the values are truncated. Is there any way to display the values?
Online
Re: Values truncated for small values in bar chart control
Reply #1 - Sep 6th, 2017 at 9:08am
You could add label texts as annotations when you detect small values. We'll try to implement built-in label to annotation conversion for next release.
abhi dhotre
Reply #2 - Sep 21st, 2017 at 6:24pm
Can you share a sample source code for doing above change? I'm unaware of working with annotations.
Online
Reply #3 - Sep 22nd, 2017 at 10:25am
Added to the barchart code you posted in earlier thread -
new DataObject { MonthCount = 2, TheMonth = "Mar", A = 300, B = 10 },
var labels = new List<string>();
var values = new List<double>();
foreach (var dataItem in dt)
	if (dataItem.B < 20)
		labels.Add(dataItem.B.ToString());
		values.Add(dataItem.A + dataItem.B); // bring it to stack's height
	else
		labels.Add("");
		values.Add(0);
barChart1.Annotations = new ObservableCollection<Series> { new SimpleSeries(values, labels) };
This will show annotation rectangles with full text where bar values are smaller than 20. You'd probably want to change the 20 threshold with a calculated value that depends on your chart's max Y range.
