Hot Topic (More than 10 Replies) Outer labels doesn't work with horizontal stacked bar chart (Read 9615 times)
abhi dhotre
Sep 21st, 2017 at 8:48pm
It works fine when the bar chart is not stacked. Please refer to attached screenshot below.
Abhi
Online
Re: Outer labels doesn't work with horizontal stacked bar chart
Reply #1 - Sep 22nd, 2017 at 3:42pm
Labels of stacked bars are drawn above their bars in horizontal stacks, or rotated on right side of bars when vertical. I.e. if you had outer labels for the other series you'd see labels above the red and yellow bars too. We could add an option to pull all labels on the right of the whole stack if that's what you expect.
abhi dhotre
Reply #2 - Sep 27th, 2017 at 5:32pm
Thank you Slavcho. Yes, I'm expecting them to be on the right-hand side of the whole stack.
Abhi
Online
Reply #3 - Sep 28th, 2017 at 5:58pm
Try the StackOuterLabels property from this build -
https://mindfusion.eu/_beta/chart_stacklabels.zip
If enabled, it will draw labels stacked on top of the vertical bar stack, or to the right if horizontal bars.
abhi dhotre
Reply #4 - Oct 2nd, 2017 at 9:30pm
Hey, Slavcho,
The labels got rotated 90 deg after setting the stack outer label property i.e. the orientation changed from horizontal to vertical. I have attached a screenshot for ref, also I have PM you code I'm using.
Online
Reply #5 - Oct 3rd, 2017 at 7:00am
Hi Abhi ,
It's by design, so the chart can fit more labels when each series in the stack adds one. I guess we can implement a special case for when there's a single label for the whole stack, or add a property for rotation angle.
abhi dhotre
Reply #6 - Oct 3rd, 2017 at 2:08pm
I was expecting something like this for the stacked chart control also. Horizontal Outer data labels like shown in the screenshot below.
Abhi
abhi dhotre
Reply #7 - Oct 13th, 2017 at 2:16pm
Hi Slavcho,
When can I expect new control libraries with rotation angle included for charts?
Abhi
Online
Reply #8 - Oct 17th, 2017 at 10:35am
Hi Abhi,
This build adds OuterLabelRotation property -
barChart1.OuterLabelRotation = 0;
Works only for horizontal bar stacks at this time. We'll try to implement remaining cases in next few days.
abhi dhotre
Reply #9 - Oct 17th, 2017 at 3:41pm
Thanks a lot, Slavcho. It's working perfectly now.  Smiley
Online
Reply #10 - Nov 9th, 2017 at 2:58pm
This build adds BarChart.InnerLabelRotation property you requested earlier too -
https://mindfusion.eu/_beta/inner_rotation.zip
