Normal Topic A question about diagram! (Read 3085 times)
chowy
Sep 25th, 2017 at 3:06am
I set the diagram.Margin="100,100,0,0",When the initialization is complete, I use the mouse click diagram, diagram of the scroll bar will scroll to the lower right corner.And, every time I drag the Node from the NodeListView to the diagram, and then click Node, the scroll bar will automatically scroll.
Now I want to implement the user can drag the drawing area. I am by setting the value of Margin.Top and Margin.Left dynamically. If the scroll bar to automatically scroll, then it affects the user experience. I set the diagram.AutoScroll = False is invalid.
Re: A question about diagram!
Reply #1 - Sep 25th, 2017 at 10:05am
You can let users drag the drawing area by setting diagram.Behavior = Pan or PanAndModify. Margin is inherited from base Control class and we don't have any built-in code handling it, if you need to set Margin for anything else our developer will check why it breaks auto-scroll.
chowy
Reply #2 - Sep 30th, 2017 at 7:43am
Slavcho wrote on Sep 25th, 2017 at 10:05am:
The Pan method provided by Mindfusion can not drag the reduced diagram. I want to achieve the effect of gif pictures. My idea is to set the margin when dragging the mouse. But now that is set once the margin, the mouse click on the upper left corner of the curve will scroll to the top. Just like the effect of the second gif picture.
Reply #3 - Oct 2nd, 2017 at 4:50pm
That seems to be related to keyboard focus. When you click the diagram it requests focus in order to receive keyboard events, and apparently the scroll viewer brings focused components into view automatically (scrolling them to top-left position). Upon next clicks, when the diagram is already focused, it no longer jumps to the origin point. It also doesn't jump if Focusable is disabled -
diagram.Bounds = new Rect(0, 0, 2000, 2000);
diagram.Margin = new Thickness(200, 200, 0, 0);
diagram.Focusable = false;
diagram.AutoScroll = true;
So you might disable Focusable while in your app's drag mode, or otherwise call diagram.Focus from code before entering drag mode, followed by ScrollX/Y assignments that restore scroll position to original one.
Otherwise non-zero Margin doesn't seem to cause problems with hit-testing and drawing, all's fine in our test after the diagram gets the keyboard focus or if focus is disabled.
chowy
Reply #4 - Apr 26th, 2018 at 10:44am
Slavcho wrote on Oct 2nd, 2017 at 4:50pm:
Thanks!
This problem has troubled me for a long time and finally solved it. Smiley
