Hot Topic (More than 10 Replies) Center handler hittest & TouchThreshold (Read 8716 times)
Re: Center handler hittest & TouchThreshold
Reply #15 - Feb 5th, 2018 at 11:36am
I guess it might still be loading a design.dll from the main installation, it's pointed by a registry key added by the installer. So maybe check if you are overwriting the design.dll assemblies located under clr4/design folder. We'll try to release this with a small update in a few days anyway.
Kyle Chen
Reply #16 - Feb 6th, 2018 at 2:19pm
OK. Great. I can wait for that release. Thank you Slavcho!
Kyle Chen
Reply #17 - May 22nd, 2018 at 2:16pm
Hello Slavcho,
Sorry I have to re-open this post again.
After running the beta version for a while, looks like we have to disable the center handles(to link nodes) otherwise it's hard to move the node, especially when the nodes is a small one. I set the TouchThreshold to 4.
Is there easy way to do this?
Thanks!
Kyle
Reply #18 - May 25th, 2018 at 9:59am
Hi Kyle,
Set HandlesStyle to Custom and handle Draw/HitTest events -
void OnDrawAdjustmentHandles(
	object sender, MindFusion.Diagramming.DrawItemEventArgs e)
	var node = (DiagramNode)e.Item;
	var style = node == diagram.ActiveItem ?
		diagram.ActiveItemHandlesStyle :
		diagram.SelectedItemHandlesStyle;
	InternalUtils.DrawSelHandles(
		e.Graphics,
		style,
		diagram.DisabledHandlesStyle,
		node.Bounds,
		node.RotationAngle,
		node.EnabledHandles,
		true,
		HandlesStyle.SquareHandles2,
		diagram.AdjustmentHandlesSize,
		new RenderOptions());
void OnHitTestAdjustmentHandles(object sender, HitTestEventArgs e)
	node.HandlesStyle = HandlesStyle.EasyMove;
	AdjustmentHandle handle = node.HitTestHandle(e.MousePosition);
	if (handle == null && node.ContainsPoint(e.MousePosition))
		handle = new NodeAdjustmentHandle(NodeHandleType.Move);
	e.HitResult = handle;
	node.HandlesStyle = HandlesStyle.Custom;
Kyle Chen
Reply #19 - May 30th, 2018 at 6:55pm
Hello Slavcho,
I changed the HandlesStyle to Squarehandles2 directly and it has the similar effect as the code you provided. We also can resize a node from the whole edge area, not only the small handles. It is much better.
Thank you very much!
Kyle
