Normal Topic DiagramLink::Route() method fails in certain condition (Read 3201 times)
Robin
Oct 25th, 2017 at 7:56am
Using Diagraming.Wpf version 3.5.0.451.
When trying to connect a Symbol whose width is more or equal to twice its height the DiagramLink::Route() method returns false and doesn't fire any event.
When rotating the symbol 90°, the routing then succeeds without any issue.
What could be causing this / is this a known issue?
Re: DiagramLink::Route() method fails in certain condition
Reply #1 - Oct 25th, 2017 at 9:19am
If using GridRouter check if it's not same problem as in https://mindfusion.eu/Forum/YaBB.pl?num=1506416396 , and try latest v3.5.2 for the fix.
Robin
Reply #2 - Oct 25th, 2017 at 11:04am
Hi Slavcho,
Thanks for the answer. I have tried with version 3.5.1.451 and the problem is still there. I don't know where to find version 3.5.2.
Best,
Robin
Reply #3 - Oct 25th, 2017 at 11:27am
Hi Robin,
v3.5.2 should be available on your account page (log in from our website title page) and as nuget package too -
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/
Robin
Reply #4 - Oct 25th, 2017 at 12:05pm
I am now using version 3.5.2.
When trying to Route from a rectangle symbol (see attachment 1) the method DiagramLink::Route() returns false and doesn't fire any event. If I rotate the symbol 90° then the Route works flawlessly. I have noticed trough trial and errors that the Routing fails only when trying to Route from a symbol which is more than 2 time wider than its height. In this use case the width of the symbol is 128, the height is 64 and the grid size is 16.
Robin
Robin
Reply #5 - Oct 25th, 2017 at 12:07pm
Here is the failing method:
Reply #6 - Oct 25th, 2017 at 12:15pm
Is that rectangle pointed by the link a separate node (placed over the larger symbol node)?
Robin
Reply #7 - Oct 25th, 2017 at 12:26pm
Yes it is a DiagramNode.
The same issue also occurs when connecting a symbol directly to another symbol.
Reply #8 - Oct 26th, 2017 at 5:50am
The router marks the grid tiles covering whole bounding area of node as obstacles, not just the ones where you see node's pixels. E.g. the grid built from diagram would look as upper part of the attached image, not the lower one. So it might not be finding free tiles to pass the link through because of the larger overlapped node and returns false. We cannot do pixel-by-pixel analysis of custom shapes to build a more fine-grained grid than that, but could add some method to let you return a list of rectangles if that will work for you.
It working when the large node is rotated might be coincidence, say if the smaller node happens to intersect four grid tiles in one case and just one in the other, depending on where the grid tiling starts.
