Normal Topic A special situation can not link (Read 2141 times)
chowy
Oct 25th, 2017 at 8:45am
When I created an arc, and assigned an anchorpoint, but this point is not on the arc. Is a floating anchor, at this time can not link. Only drag the diagramlink to the arc, will automatically docked to the specified anchor. I would like to directly drag the diagramlink to the anchor, directly to the connection. Is there any way to achieve it?
For example, the arc in the picture and the anchor of 'X'.
Re: A special situation can not link
Reply #1 - Oct 25th, 2017 at 9:25am
Check if AutoSnapLinks and AutoSnapDistance properties will work for you. Otherwise we'd need to extend hit-testing methods of nodes to check for points outside of their Bounds, or if you are already using a custom class you might try overriding ContainsPoint method yourself.
chowy
Reply #2 - Oct 27th, 2017 at 6:00am
I have rewritten the ContainsPoint method, but in the small red rectangle, it is not triggering the ContainsPoint method when it moves very small.
Reply #3 - Oct 30th, 2017 at 7:43pm
This works for me, for drawing links both to and from external anchor point -
public class MyNode : ShapeNode
	public override bool ContainsPoint(Point diagramPoint)
		if (AnchorPattern != null)
			const double hitTestDist = 10;
			foreach (var point in AnchorPattern.Points)
				var r = Bounds;
				var x = r.X + r.Width * point.X / 100;
				var y = r.Y + r.Height * point.Y / 100;
				if (Math.Abs(x - diagramPoint.X) < hitTestDist &&
					Math.Abs(y - diagramPoint.Y) < hitTestDist)
					return true;
		return base.ContainsPoint(diagramPoint);
