Normal Topic Exporting diagram as Image file leads to Out of Memory Error (Read 5190 times)
Gaurav Dubey
Oct 27th, 2017 at 1:25pm
We have requirement of exporting Diagram to Image file(jpeg,png and gif), However doing this cause out of memory exception.
Reason could be image have high resolutions(22348x4282) pixels.
I am using diagram.createImage( BufferedImage.TYPE_INT_RGB) method to create image and writing it using ImageIO.write api.
Is there any better way to do the same to overcome out ot memory error while writing image in file?
Re: Exporting diagram as Image file leads to Out of Memory Error
Reply #1 - Oct 27th, 2017 at 1:49pm
Is createImage itself throwing memory exception or ImageIO.write?
Gaurav Dubey
Reply #2 - Dec 21st, 2017 at 7:29am
ImageIO.write because if components are in good amount in diagram, then image size is more than 7 to 10 MB or so, and i could not find a way to create image with less resolution.
So due to size of image, application crashes while using ImageIO.write.
Reply #3 - Dec 21st, 2017 at 10:38am
We don't plan writing low-level image encoding code at this time. Try splitting the produced image into smaller ones in memory, write them into separate files, and use external tool to glue them in a large file. E.g. try ImageMagick / JMagick -
https://www.imagemagick.org/script/index.php
https://www.imagemagick.org/discourse-server/viewtopic.php?t=11320
If you are on older Java version, you might also check if latest JRE9 is able to serialize larger images.
