Normal Topic Need to show specfic node at specfic place (Read 1608 times)
Shafi
Nov 8th, 2017 at 11:12am
Hi
I have requirement that i need to show some specific order. for example
we have 5 different nodes let say 1 2 3 4 5
After applying layered layout. I need to show it like node 3 will be first shown
like
3 -> 2->1->4->5
How can we achieve this can you please let me know?
Online
Re: Need to show specfic node at specfic place
Reply #1 - Nov 8th, 2017 at 11:29am
LayeredLayout assigns layers according to link direction. If node 3 has only outgoing links, it should be placed on first layer.
Shafi
Reply #2 - Nov 8th, 2017 at 11:40am
Is  there any other layout  which will be helpful this kind of requirement. Or what should i do achieve this kind of functionality.
As this not the hard and fast rule for me that node 3 is having only out-going links only.
Online
Reply #3 - Nov 8th, 2017 at 1:20pm
If you just need to arrange nodes in a row disregarding their links, you could loop over them in the order you need and set their Bounds calculated from current counter value. Something like -
for (var i = 0; i < ...)
    nodes[i].setBounds(new Rect(i * 60, 20, 40, 30));
