Normal Topic VISIO export- Add header in diagrams (Read 4419 times)
Ron Floyd
Nov 9th, 2017 at 2:53pm
HI,
Is there any way where we can add the header in the diagram that we export it in VISIO.
I already have javascript license and I am trying out the ASP.NET dll to download mindfusion diagrams in the VISIO.
Please reply.
Ron
Re: VISIO export- Add header in diagrams
Reply #1 - Nov 9th, 2017 at 3:02pm
If by headers you mean ones added via Diagram.LaneGrid, you can export the grid as Visio's Functional Band object by setting the VisioExporter.ExportLanes property.
Ron Floyd
Reply #2 - Nov 10th, 2017 at 1:10pm
HI Slavcho,
Thank you for your response.
Is there any way where I can find the example?
I am using JSON data to create Diagram Nodes and Links using DiagramView class.
Is there any way where I can create a header text in the exported VISIO diagram, which will basically be the info about what the diagram is about.
Ron
Reply #3 - Nov 10th, 2017 at 1:41pm
Hi Ron,
If only that, you could implement the header as a locked ShapeNode on top of the diagram, possibly using a different styling than the actual nodes. Add it temporarily before export if it shouldn't be shown on screen but only when exported.
