Normal Topic Need add SVG image in diagram node (Read 2489 times)
Shafi
Nov 23rd, 2017 at 8:24am
Is there any api which will accept SVG image inside diagram Node?
Lyubo
MindFusion team
Re: Need add SVG image in diagram node
Reply #1 - Nov 23rd, 2017 at 10:14am
You can use SVG images like other image types like PNG, JPG, etc, like shown here: https://mindfusion.eu/Forum/YaBB.pl?num=1511255550/1#1.
Please note that if you use a base64 encoded image, the prefix is different that in the post above - you should use 'data:image/svg+xml;base64,' and then the base64 encoded string itself.
Lyubo
Shafi
Reply #2 - Nov 23rd, 2017 at 11:02am
Thanks for reply
One last question if need add a css class like below in our diagram node. Can we use this?
As i have used it in diagram it does not the image.
Code (Javascript)
icon-system {
    background-image: url('@{images}/indicatorSystemNew16.svg');
Lyubo
MindFusion team
Reply #3 - Nov 23rd, 2017 at 11:36am
You can't use CSS to style individual elements in the diagram, as it uses the HTML5 Canvas API for drawing. If you wish to show images inside nodes, you should use one of the methods discussed above.
If you wish to create something like a template for your nodes, you can also look into the CompositeNode class - how it's used is shown in Tutorial4 sample from the JsDiagram package.
Lyubo
