Normal Topic Draw Custom Vertical line on Diagram (Read 3669 times)
ashar11
Dec 11th, 2017 at 10:57am
Can you please tell me how can I draw a custom vertical line on diagram by defining it x y co-ordinates for location and also the length when diagram is loaded or initialized first time, I am using wpf flowcharter
Lyubo
MindFusion team
Re: Draw Custom Vertical line on Diagram
Reply #1 - Dec 11th, 2017 at 11:36am
You can use the CreateDiagramLink(point, point) overload through the Diagram.Factory property.
To access the diagram dimensions, use the Bounds property.
Lyubo
ashar11
Reply #2 - Dec 11th, 2017 at 1:40pm
By using the below code which you provided I have created the line, but its an anchor, can i draw it without having arrow and selection property. Thanks
  Point P = new Point();
            P.X = 70;
            P.Y = 0;
            Point P2 = new Point();
            P2.X = 70;
            P2.Y = 200;
            diagram.Factory.CreateDiagramLink(P,P2);
Lyubo
MindFusion team
Reply #3 - Dec 11th, 2017 at 2:54pm
Modify your code like this:
var link = diagram.Factory.CreateDiagramLink(P, P2);
link.HeadShape = null; // remove the arrow shape;
link.Locked = true; // prevent interaction with the link.
Lyubo
ashar11
Reply #4 - Dec 12th, 2017 at 6:21am
thanks
ashar11
Reply #5 - Jan 19th, 2018 at 7:41am
Hi
   I am facing an issue, when ever i drop the shape node on this custom line it moves or bend , so how can i make it immovable.
thanks
Reply #6 - Jan 19th, 2018 at 8:50am
Set link.AutoRoute to false.
ashar11
Reply #7 - Jan 19th, 2018 at 9:50am
Still its not working , link is bending or moving
           Point h = new Point();
                        h.X = 0;
                        h.Y = 400;
                        Point h2 = new Point();
                        h2.X = 5000;
                        h2.Y = 400;
                        var link2 = diagram.Factory.CreateDiagramLink(h, h2);
                        link2.HeadShape = null;
                        link2.Locked = true;
                        link2.AutoRoute = false;
Reply #8 - Jan 19th, 2018 at 10:50am
Check if you aren't calling link.Route or diagram.RouteAllLinks yourself from some event handler. Also the above code might create the link bent if diagram.RouteLinks is enabled. In that case, set link.Shape to Polyline and link.SegmentCount to 1 after creation to straighten it back up.
