Normal Topic Undo/Redo in Diagram.LaneGrid (Read 1795 times)
David Long
Dec 20th, 2017 at 3:32pm
I am using version 6.4.1. There does not seem to be support for Undo/Redo to changes in the LaneGrid, e.g. Adding/Removing rows and columns. Is this feature coming or do I do it the hard way!
DavidL
Re: Undo/Redo in Diagram.LaneGrid
Reply #1 - Dec 20th, 2017 at 9:08pm
Sorry, the hard way -
void OnDiagramAddRow(object sender, EventArgs e)
	diagram.ExecuteCommand(
		new AddGridRowCmd(diagram, "row"));
class AddGridRowCmd : Command
	public AddGridRowCmd(Diagram diagram, string title) : base("Add grid row")
		this.diagram = diagram;
		this.title = title;
	protected override void Execute(bool undoEnabled)
		header = new Header(title);
		diagram.LaneGrid.RowHeaders.Add(header);
	protected override void Undo()
		diagram.LaneGrid.RowHeaders.Remove(header);
	protected override void Redo()
	Diagram diagram;
	string title;
	Header header;
David Long
Reply #2 - Dec 23rd, 2017 at 9:39pm
OK, Thanks for your help. I will do similar classes for deleting rows/columns, changing row/column height/width etc...
Regards
David
