Normal Topic Can I Limit Text That Can Be Entered For Link Text (Read 1615 times)
alukes
Dec 22nd, 2017 at 3:51am
I want to limit what a user can enter after double clicking a link to Y or N.
Is that possible?
If not, can I display suggestions in the text box when the text box is displayed?
or can I check the users input and display an error message?
Or any other idea you might have.
Re: Can I Limit Text That Can Be Entered For Link Text
Reply #1 - Dec 22nd, 2017 at 9:54am
You could handle enterInplaceEditMode event to get a reference to the text box, and attach some validation / suggestion library to it. Alternatively handle createEditControl event and you could set a checkbox or a select element as editor -
diagram.addEventListener(Events.createEditControl, onCreateEditor);
function onCreateEditor(sender, args)
	var select = document.createElement("select");
	var yes = document.createElement('option');
	yes.value = "Yes";
	yes.innerHTML = "Yes";
	select.appendChild(yes);
	var no = document.createElement('option');
	no.value = "No";
	no.innerHTML = "No";
	select.appendChild(no);
	args.setControl(select);
	var bounds = args.getBounds();
	select.style.position = 'absolute';
	select.style.left = bounds.x + 'px';
	select.style.top = bounds.y + 'px';
	select.style.width = bounds.width + 'px';
	select.style.height = bounds.height + 'px';
	select.style.zIndex = 2;
	document.body.appendChild(select);
« Last Edit: Dec 22nd, 2017 at 4:30pm by Slavcho »
alukes
Reply #2 - Dec 23rd, 2017 at 3:23am
Copied and pasted. Worked perfectly.
Thanks for your usual excellent support.
