Normal Topic Timetable mode and resources (Read 3472 times)
fractal07
Jan 5th, 2018 at 10:57am
My C# winforms app displays a daily timetable with resources (employees) but each day, employees can be different. I manage appointments for all resources but is there a simple way to select (filter?) which resource I can display when I navigate to the next/prev day (cf. pictures below)?
Kind regards and congratulation for your great products!
Re: Timetable mode and resources
Reply #1 - Jan 5th, 2018 at 1:16pm
Thank you for your feedback.
There is no automatic way to select specific resources for different days. However, you can easily do this yourself by selecting the resources to group by when the current day is changed. For example, if you group by contacts, you can use the following code to select different resources:
calendar.Contacts.Clear();
calendar.Contacts.Add(contact1ForTheNewDay);
calendar.Contacts.Add(contact2ForTheNewDay);
To get notified when the day is changed through the navigation buttons inside the Calendar control, use the Calendar.VisibleDateChanged event.
