Normal Topic Parallel Adjustment Handle (Read 1472 times)
ashar11
Jan 26th, 2018 at 11:26am
After creating a link between two nodes, when i click and move adjustment handle it only moves that selected one which is fine and given by default. Is it possible by moving the one adjustment handle the other one starts moving parallel to it in case of two adjustment handle.
Re: Parallel Adjustment Handle
Reply #1 - Jan 26th, 2018 at 11:30am
Yes, that's what should happen if you set link.Shape = Cascading;
ashar11
Reply #2 - Jan 26th, 2018 at 11:35am
It worked, Thanks
