Normal Topic Control click selection selected items + control drag select (Read 4168 times)
tjugg
Feb 21st, 2018 at 8:19am
Can I somehow override behavior like this:
I control click 3 symbols -> 3 symbols are selected.
I control + mouse drag over other 3 symbols -> now only these 3 new ones are selected.
T
Re: Control click selection selected items + control drag select
Reply #1 - Feb 21st, 2018 at 11:58am
It seems that's how it works by default, I'm testing in the demo project. Check you aren't already overriding that by handling some selection events if it's different for you.
tjugg
Reply #2 - Feb 21st, 2018 at 12:08pm
I took all custom behavior off and it still behaves like I wrote in the OP.
It works if I first drag select multiple nodes and THEN control click other nodes, but not the other way around. So control click 3 nodes -> 3 nodes selected -> control drag over 4 other nodes -> now 4 nodes selected
// T
Reply #3 - Feb 21st, 2018 at 12:25pm
Do you mean you need ctrl+drag to add to selection?
tjugg
Reply #4 - Feb 21st, 2018 at 12:45pm
Yes
Reply #5 - Feb 22nd, 2018 at 8:16am
We have property for this in Windows Forms version, and will implement it in WPF for upcoming release -
https://www.mindfusion.eu/onlinehelp/flowchartnet/P_MindFusion_Diagramming_Selec...
tjugg
Reply #6 - Feb 22nd, 2018 at 10:17am
Okay, thanks for the information!
// t
Reply #7 - Feb 26th, 2018 at 9:32am
Try setting following with this version -
https://mindfusion.eu/_beta/wpfdiag353.zip
diagram.ModifierKeyActions.Control = ModifierKeyAction.ExtendSelection;
The Selection.ExtendMode property is checked when using the SelectionOnly behavior and drawing lasso without Ctrl key.
