Normal Topic DiagramLink Intersects check using Node bounds as parameter (Read 2393 times)
beetee
Mar 26th, 2018 at 2:25pm
Hello
We allow the user to select a node and move it in the diagram using the Keys(Up/Down/Left/Right). This is implemented in Key Press event handlers. We have to restrict the movement of nodes when it intersects any of the other links in the diagram. We use the DiagramLink.Intersects while moving a node with mouse and it works perfectly. We want to achieve the similar functionality for key press as well.
Is there any API available that take the Bounds of the Node and check if it Intersects with a link? We want to restrict the Key press event in this case so that the node will not intersect the link after it is moved. For that we should know that new Bounds of the Node will not be intersecting with any of the nodes after the movement.
BT
Re: DiagramLink Intersects check using Node bounds as parameter
Reply #1 - Mar 26th, 2018 at 6:57pm
Try this approach -
var hitTester = (DiagramNode)movedNode.Clone(false);
var testRect = movedNode.Bounds;
testRect.Offset(-20, 0);
hitTester.Bounds = testRect;
foreach (var link in diagram.Links)
	if (link.Intersects(hitTester))
beetee
Reply #2 - Mar 27th, 2018 at 6:47am
Hello Slavcho,
Thank you for the quick reply.
I have tried your suggestion.
As soon the execution hit the statement
Application is in break mode.
D:/Delete/2018-03-27_08-37-16.png
BT
Reply #3 - Mar 27th, 2018 at 7:29am
If it's a custom node class you might have to create a copy constructor. Or just create an instance of rectangular ShapeNode there instead of cloning if you only care about rectangular boundaries.
