Normal Topic override DrawLinksBehavior to cohabitate with Pan (Read 2792 times)
Thomas Falcone
May 3rd, 2018 at 3:38pm
Hi, I'm currently searching a way to make the DrawLinksBehavior cohabitate with the PanBehaviour. (so the user can pan while creating a link without reseting the link being created nor the visual feedback).
I found another post of this issue but it was for android. Is there a fancy way to do it in c# ?
Re: override DrawLinksBehavior to cohabitate with Pan
Reply #1 - May 3rd, 2018 at 4:58pm
Panning while drawing a link sounds like automatic scrolling -
diagramView.Behavior = Behavior.DrawLinks;
diagramView.AutoScroll = true;
Or do you mean pressing additional mouse button to enable pan mode while also holding the left one for drawing?
Thomas Falcone
Reply #2 - May 4th, 2018 at 7:44am
Sorry if it wasnt clear, it's actually the second behaviour i'm trying to implement.
=> Or do you mean pressing additional mouse button to enable pan mode while also holding the left one for drawing?
But actually, the Drawlink interraction is cancelled by the pan.
So I would like to restart a new drawlink after a pan if a previous drawlink was active at the begining of the pan.
It looks like it is possible but I cant find a way to achieve it.
Reply #3 - May 7th, 2018 at 11:24am
The Behavior classes can track only a single mouse button (pressing a second button cancels the current interaction), so it's not possible to handle two buttons out of the box. You can still implement simultaneous panning by overriding mouse event handlers in a custom DiagramView class -
class MyDiagramView : DiagramView
	protected override void OnMouseDown(System.Windows.Forms.MouseEventArgs e)
		base.OnMouseDown(e);
		if (e.Button == MouseButtons.Right)
			prevPanPoint = ClientToDoc(e.Location);
			panning = true;
	protected override void OnMouseMove(System.Windows.Forms.MouseEventArgs e)
		base.OnMouseMove(e);
		if (panning)
			var currentPoint = ClientToDoc(e.Location);
			ScrollX += prevPanPoint.X - currentPoint.X;
			ScrollY += prevPanPoint.Y - currentPoint.Y;
			RecreateCacheImage();
	protected override void OnMouseUp(System.Windows.Forms.MouseEventArgs e)
			panning = false;
		else
			base.OnMouseUp(e);
	PointF prevPanPoint;
	bool panning;
Thomas Falcone
Reply #4 - May 9th, 2018 at 9:42am
Looks like a good way to implement the required behaviour. Thanks a lot, I'll keep updated if i make it work out.
Thomas Falcone
Reply #5 - May 31st, 2018 at 3:41pm
Tried it, it was slopy and didnt fit the requirements, but I found a way to implement it (bypassing interactions) and users were happy.
Thanks anyway Smiley
