Normal Topic java swing calendar (Read 7144 times)
Randa
java swing calendar
May 19th, 2018 at 11:03pm
hello, first of all thnx for the JPlanner trial its a greate tool, but i had some errors while implementing the code, ill be more than thankful if u could help.
my errors are in the MainWindow in the customEvents.
errors:
1) content.add(calendar);
// The method add(Component) in the type Container is not applicable for the arguments (Calendar)
2) if (e.getElement() == CustomDrawElements.TimetableItem)
// Incompatible operand types CustomDrawElements and long
3) java.awt.Font font = e.getStyle().getFont();
// Type mismatch: cannot convert from com.mindfusion.drawing.Font to java.awt.Font
Thanks in advance:)
Re: java swing calendar
Reply #1 - May 21st, 2018 at 5:21am
That will happen if you use old code with version 2.0 of the control. See https://mindfusion.eu/Forum/YaBB.pl?num=1497361362 for what's changed in latest version.
Randa
Reply #2 - May 21st, 2018 at 11:26pm
i downloaded the JPlanner trial, the latest version and copied the code. So it should be the new code with the version 2.0. any help?
Reply #3 - May 22nd, 2018 at 7:33am
Where have you copied code from?
Randa
Reply #4 - May 22nd, 2018 at 12:53pm
from your website, i downloaded the jplanner trial. and copied the code from the package customEvents, mainwindow and basewindow
Reply #5 - May 22nd, 2018 at 7:09pm
That sample compiles and runs successfully for me. Also latest version does not contain a com.mindfusion.drawing.Font class, so my guess is your project has older jplanner.jar version listed in its libraries path. Maybe you got the older jar downloaded along with another example from our blog / video channels. Replacing the older jar with one from latest distribution should let you compile latest sample code.
samaravasthi
Reply #6 - Mar 18th, 2019 at 5:13am
How to use jdatepicker to display calendar component.
java programming
« Last Edit: Mar 19th, 2019 at 4:28am by samaravasthi »
Iva_P
Reply #7 - Mar 18th, 2019 at 5:24pm
we've created a demo application that renders a DateTime picker. You can download it from this link:
https://mindfusion.eu/samples/java/scheduler/DateTimePicker.zip
